fastbike02
I have a 2010 ram sport that I attempted to do a projector/hid conversion. I bought the cheap conversion harness off ebay (big mistake) everything was fine on the driver side but the pass side made a nice buzzing sound from the hid ballast followed by nothing and now even with the factory headlights in I have no high or low beams on the pass side. I couldn't figure out how to reset the tipm with alfaobd but all the fuses were good. Right now I have the battery cables off (going to leave it that way overnight) but what else should I check? (headlight works fine if moved to driver side) I know I can rig up relays from the driver side but would rather fix it properly if possible! I also got a set of retroshop conversion harnesses on the way.
