Help with identifying
Jomikesimpson
Missouri
I keep getting these error codes. Where do I start? Bulbs are working. Sockets were working and now are bad. I believe fuse is good because wires are testing hot at tail light harness. Only Led lights are in high beams. Any help would be appreciated. a25599e64f6caa4668ffb6a36e93bf55.jpg
Sent from my SM-G955F using Tapatalk
Tach_tech
5.7L HEMI
Could be wiring, or the BCM. There should be a - then 2 more numbers after those codes to show which circuit and what fault is being set.
Both tail lights share the same ground circuit so that would be a good place to look. Do all the brake lights,tail lights, signal lights work properly? Any flashing fast.
Jomikesimpson
Jomikesimpson
Missouri
Thanks for your reply. I actually found the problem. Hopefully. I had a bad bulb. Doesn't make sense to me. I replaced both bulbs and it works. Guess i will see if it stays that way.
electricalservice
