Help with Odometer Issue on 1992 Dodge Ram B350
Engracia Grace
Spain
5.9L V8
Hi everyone, I hope this message finds you well. My name is Grace, and I am the owner of a 1992 Dodge Ram B350. Currently, I am experiencing an issue with the odometer in my vehicle, as it has stopped working and no longer advances with the mileage.
I am living in Spain and have had difficulty finding a mechanic who specializes in this type of vehicle. Since I cannot pass the ITV (Vehicle Inspection) due to this issue, I would like to know if you could provide me with any information or instructions on how to fix this problem, or if there is a specialized shop that can assist with the repair.
I would greatly appreciate any guidance or recommendations on how to proceed with fixing this issue.
I look forward to hearing from you.
Thank you in advance for your help.
1H22
Canada
1997 dodge ram 2500, 2015 ram 2500, 2018 ram 2500
5.9L 12valve Cummins, 6.7L cummins
Hi Grace,
there is 2 sensors that feed the pcm info to calculate speed, i would start by looking to make sure these 2 are plugged in well. there should be a wheel speed sensor on your rear differential and a speed sensor on the side of the transmission, checking these connections would be a good start.
RC
