Hi guys, new member, trying to repair an 03 1500 w 5.7 for someone. Some systems work from time to time like radio door locks etc. Check engine light is on however when I tried to have the codes read the reader never detected that it was plugged into a vehicle. owner claims that the truck was jumped one time with the donor battery hooked up backwards and all the electrical problems started then. Truck sounds like it runs okay and the instrument cluster and transmission work fine but I'm leaning toward ecu problems. Truck starts to run hot when idling but cools down when driving. Never dealt with computer problems before and my question is where is the ECU located and can the dealership test it if I take it in to a dealership. Have most of the lower dash disassembled and am looking for burnt connectors and/or wires. Also is there a fuse block or relays inside the cab i might need to look for? Help me ram guru's. have checked all fuses and relays in the engine bay fuse block. going to flush the radiator today and make sure fan thermos are working properly.
