Help
Mishalnr
Hi guys , my truck makes a weired vibration and a sound at the same time i feel the vibration on my steering wheel and brake pedal it happens when the truck is between 500-650 ish rpm when im nearly at a complete stop or reversing it comes from the driver side in the front i took it to the dealer 3 times they couldnt figure it out they changed my engine mounts and re bolted the exhaust bolts the they said its normal because the did not know how to fix its driving me crazy ! Please help its a 2014 1500 5.7
H1Chester
I'd do a forum search. No that is not normal. There are a few posts recently about vibrations and or pulling to one direction...
M
Mishalnr
Can you send a link to it i couldn't find one i appreciate the help
Pull Ya
Cedar Creek, Tx
Do you have stock wheels and tires?
Jay
Saltillo Express
2 or 4 wheel? 500-600rpms? that's like at idle. Is it moving when it makes the sound or sitting still?
M
Mishalnr
As soon as it moves it makes the noise but even if its idling i feel the vibration and little noise and when i turn the ac on it gets louder and more vibration
M
Mishalnr
Its a 4x4 it happens on idle and if i just let go of the brakes and if i turn the wheel and if the ac it kinda gets more noticeable
M
Mishalnr
ColdCase
Does the fan belt looks OK? No glazing, smooth spots?
Is it like the engine running rough, like a misfire, at idle or under a small load like the AC or power steering. Pop the hood so you can see the motor at idle and turn on the AC, turn the wheel back an forth and notice any rocking.
I think I read somewhere of the idler pulley, or one of the others, loosening up and you get vibrations at idle but smoother otherwise. If the fan belt is loose you may get some slippage at idle.
M
Mishalnr
I checked the fan its good its not making the noise
joshhhh
