Help
Mishalnr
I have a 2014 1500 5.7,,,,, my passenger side head lamp bulbs went out (low&high) so i changed them then shortly again they went out ! so i changed them again but this time it only stayed on for like 5 seconds then now it won't work and i got the message on my cluster
Burla
2010 Hemi Reg Cab 4x4
You have a short somewhere, or faulty ground.
huntergreen
Marine Corps Navy Badge
check the pins in the connector.
M
Mishalnr
Looks good it has no signs of burning
MADDOG
Living in a Firepit
6.4L HEMI
Look inside the connector to see if there are any dirty, corroded or burnt points.
Check your harness back from the connector to the wiring loom. Look for insulation chafing or bare wire.
M
Mishalnr
I unplugged the connecters then i put them back on i only turned on the low beam after 2 days i used the high beam the second i flashed the HB it turned off the low and the high beam together and i got the message on the cluster the driver side headlight works fine
