cptwing
- Aug 14, 2014
- 1,446
- 497
- Location
- The Soviet State of Connecticut
- 2014 3500 ST DRW REG CAB
- 6.4l Hemi
Found this on just answer, but you probably already knew this, but just in case.
Hello and welcome to just answer. Let me see if I can help you with this. This is a code for the transmission's governor pressure sensor. Whenever we see this code at the shop, we drop the transmission oil pan and replaced the governor pressure sensor and the governor pressure solenoid, because either one can set this code. If you are fairly mechanically skilled, and have the means to remove the trans pan, then this is something that is not too difficult to replace.
I hope this information helps and let me know if you need further assistance with this..
Chris
Chris
