Hernando county, fl. 2016 1500 in need of tuner/calibrator for wheels.
Mikey G
Weeki Wachee, FL
3.6L
I live in Hernando County, FL, and i cannot find a single place that has a speedometer calibrator for my oversize tires. I bought a 2016 ram 1500 3.6L that had pre-installed aftermarket rims/tires that were not calibrated to the speedometer/odometer and not a single dealership had the tool to do it apparently, and i called 10-15 different shops/speed shops and they also did not have the tool needed. I was told to just purchase a tuner myself but mine requires an ecm upgrade before i even buy a tuner, then im in over $1k. I'm new to this category so please don't be harsh, THANKS!
Firebird
2019 Ram 2500
What size did you go with? The dealer should be able to make some adjustments within reason
McBroom
Denison Tx
Hemi 6.4L
Most gps can show the speed on the display. There’s also some apps for speedometers
Blue Streak Pearl off-road
UnsatFC
Active duty NAVY
New Jersey
Hello Hernando County! I have family in Spring Hill. Have you looked into the rough county calibrator? Runs about $140 bucks and works on 2016 RAM 1500’s. Don’t need a tuner and all that stuff.
quietpeen
2021 TRX
Hellcat
Just so there is no confusion for you are anybody that does want to go the tuner route. You need an unlocked pcm not ecm
radkawi
HEMI 5.7
Get yourself the AlphaOBD program and a MX dongle. You can use them to set the diameter of your tires in the body control module (BCM) and compensate for the larger tires. I went from factory to 35" Toyo A/Ts and used the software to adjust/calibrate. Am spot on MPH to handheld GPS and now it shifts like a dream! Best mod money spent by far!
Search the forum or head over to the DIY section to read up on the program and known working changes. You'll be glad you did!
Pull Ya
Cedar Creek, Tx
Check the "Hemi Truck Club" for "keith" He is a tuner in Fld and does a great job on performance related issues.
Jay
TMFMK
