Hesitation in acceleration after first start of the day
Goal10der
2019 Ram 1500 Big Horn
Hemi 5.7 eTorque
My 2019 Big Horn does the same thing, and has since I bought it new. The dealer's service department has checked it out, re-pinged the computer, checked for error codes (it doesn't throw any when it happens), and it still does it. I've just sort of gotten used to it as a quirk in the truck. Cold ambient temperature is not the issue - in Central Florida the average "cold" ambient morning temps are in the mid to upper 70's most of the year, and it will do it as well on a cold start with mid afternoon temps in the mid to upper 80's. Maybe just an inherent thing with the 5.7.
Glen Harrison
Comox Valley , British Columbia Canada
2017 ram
My 2021 classic has done this from new as well , it is like a non responsive throttle and a stumble missfire . only for about 10 min of cold start driving .. Dealer cant find it and no answers . no codes etc. i have the 8 speed. but this hasnt even shifted up out of first gear when this is happening . So you are not alone
TBG22
5.7 V8 HEMI
Just wondering if anyone else has experienced the same thing as me on my truck, in the morning when I start it to go to work, back it out of the garage and go to drive up the street for the first little bit it has some hesitation between me pressing the Excelerator and the truck actually going forward. It feels like there’s like a dead spot or how the engine would feel if it was all gummed up or had a dusty air filter or something but none of those things are the case on my truck.
I have pulled the intake tube off the top of the engine and checked the throttle body and butterfly valve and all clean, The air filter is perfectly clean no issues there, I use good quality gas from Shell gas stations not cheap Cornerstore one off gas stations, I have no codes or lights on the dash at all, I have the non-electric fan so I know that kicks in at first it might have something to do with it a little bit but it seems like there’s more hesitation then there should be for the first minute of driving in the morning.
After this there is zero hesitation when I am out on the road driving to and from work or when the truck is already warmed up it’s just that initial first a little bit of driving after sitting all night.
Just wondering if anybody else has experienced this with their 5.7 L engine and if you found something to fix the issue or if it’s just something these engines do when they first get started after sitting for eight hours or so.
This feels like it is in the engine, not the transmission or shifting hesitation. Fees almost like it would stall out if it were any worse, but it never stalls out, just a real sudden lack of acceleration and it just dies out for a second or two then goes.
2021 Classic, 5.7L 8-speed with 3.92 gears.
Thanks for any input on this.
I’ve had this same issue. Brand new truck with only one oil change performed. You explained my issue exactly. Anyone have any suggestions?
TBG22
5.7 V8 HEMI
Sorry, after I posted this I was able to read the other posts. Will try to see if ahead starting helps or not. Thanks all.
seanhawn19
Canada
Wow. I have this exact problem with my 21 warlock. I usually start my truck and let the rpm’s drop before putting it in drive. But never really thought about it till reading this, that it drive but only feels like it has no power when I release the gas and then reapply.
The thing that ****** me off is that it didn’t do this when I first bought it.
Obviously something changed.
I due get lack of power even when it is warm sometimes as well as slightly rough idle and surging.
Chrysler installed a new transmission and valve body when I mentioned this but nothing changed. I never thought it was the transmission.
Really wish I could find a solution.
Also does anyone else have a delay going from drive to reverse or reverse to drive?
When it is cold it can take like 3 to 4 seconds. 2 to 3 when warm. Again even after a new transmission and Chrysler says it is fine. But my buddy own the same truck and doesn’t have it.
Feel like I’m getting the run around.
Nicholas Cove
London
Same with mine. 20 warlock 5.7
Probably normal, mine does it too. So did my previous pentastar and the ride before that (GM 3.8). The longer you let it warm up and idle before taking off first thing, the less it does it. It's just cold, mine did that from day one.
Dodge 1500 4X4
Rochester, NY
I have the same problem, I think it's the trans fluid before it warms up is part of the problem, once the temp comes up its better, I have the pedal commander also.
GlobalScan
Hemi 5.7 eTorque
I also have the same problem. 2022 Laramie 5.7 Hemi Torque - 8 speed Regular Gas. I replaced the stock Throttle Body with a BBK #1842 85cm. It seemed to fix the issue at first (hesitation on acceleration) however the issue still exists, but is not persistent. Hot or Cold engine does not matter. Happens ether way.
Reading all of these posts, not sure what to do next. Seems Computer reflash at dealer did not help on another post.
dork17
Canada
Has anyone found a solution to this? I'm experience the same.
ramffml
ramforum
Start it up, and wait for the RPMs to drop and fully settle. It's not something a dealer can/will fix. The hotter the engine gets on that first start before taking off, the less it will do it.
Mine doesn't "stumble", it just feels a little sleepy. Definitely take your time before giving it the beans!
EdGs
FL
Could this behavior be related to the "adaptive" transmission?
My Ram does seem sluggish at times when cold.
Really doesn't bother me much, though.
Qcman
Ottawa, Canada
5.7 liter Hemi
I’m glad I found this thread. I’ve been searching for this info. My truck does as others describe. It seems to fall flat on its face when I come to a stop right after a cold start and then try to accelerate again . Within probably 30 seconds it no longer is an issue and the truck works perfectly fine. It won’t happen again until another cold start. Outside temperature doesn’t matter can be hot in summer and still does it. I think if I didn’t have to stop and start I may have never noticed it.
I’m starting to think this is a thing with these trucks. I’m spoiled by my Mustang GT that runs smooth as silk right after starting but then it has both port and direct injection in its favour too.
hemihustlin
Lower Southwest Quebec
it is a thing with these hemi and 8 speed trucks. have not seen it reported with the RFE series transmissions and i previously owned a 545rfe/hemi truck
I have not used a scanner upon cold start to see whats going on because its pretty rare for me but after 140k kms on my warlock its definitely happened a few times per year.
I think that the factory open loop tuning is off. probably giving too much fuel. when the event happens taking off from the first stop it stutters and gulps for air. you end up giving alot of throttle to get the ******* thing moving then the cats are hot and its in closed loop.
I usually wait for the cold/fast idle to come down before taking off even then wait a bit more or give more throttle percentage to avoid this
I am curious! anyone out there running a custom or otherwise non stock tune that has this happen to them?
