HID kit help
adamsj13
idaho, USA
Hello all, I have a couple questions. I bought an innovation hid kit for my 14 ram limited, I'm able to get the balast and all the cables to fit inside the headlight housing. Is that ok to do or will it get to hot and melt everything? Next question, Do I need to put the bulb in a certain way? My headlights have the projector.
Thank you all! Sorry if this has been covered,
Wirerat
I am using an innovate 55w hid kit with balaste fit into the housing. I been running it this way a few months. So far no issues.
Clocking the bulbs means very little since the light output is very even around hid bulbs. They seemed to only fit one way in my aftermarket projectors also.
Cableman
Longisland
The bar on the bulb goes on the bottom, loosen the 3 screws holding the bulb in and clock to position and tighten screws back down. I added tape to each bulb tab just so it wouldnt clock out from vibration.
