Hid lights stopped working need help
bloombloom88
Plano, Texas
This morning on my way to work, my lights were working fine, I stopped at subway for breakfast, came out to leave and my lights would not turn on, I only had my orange corner lights and tail lights.
How do I go about problem solving this? Both headlights are dead, maybe a fuse?
I need some help getting these working ASAP or I'm gonna be getting a ticket real quick
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons make you fat...
bloombloom88
bloombloom88
Plano, Texas
Got them from JJ I can't remember the brand but it's whatever he uses. It's a 55w 5000k kit
JJP71584
Pgh, PA
Burnt out ballast or a ground that came loose maybe? If both sides went out it makes me think a connection came loose somewhere...
audio1der
Airdrie, Alberta
Good thing it's Friday and you've got the weekend, because you have troubleshooting in your future. Make a plan. Start with the easy stuff first; fuses. Then broken wires. Try using a wire for a jumper to the battery to provide temporary power or ground (1 at a time) and if that fixes it you know what you have to replace. When you do, solder and heatshrink or a brand new wire run are your best friends.
bloombloom88
bloombloom88
Plano, Texas
I'll look under the hood at lunch and see if anything came loose, hopefully it will be an easy fix. It's weird that both went out at the same time
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If they are both out, then it is most likely a loose ground, blown relay, or a blown fuse. Check those first, and then all other wiring connections.
bloombloom88
bloombloom88
Plano, Texas
Does it make any sense if the high beams still kick on? Why would the lows be dead and the highs still work?
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
Do you have dual or quad headlights? If you have quads, then the high beams are a completely different bulb and harness which is why they still come on and the lows dont.
bloombloom88
bloombloom88
Plano, Texas
I have duals
bloombloom88
bloombloom88
Plano, Texas
I just looked again to verify, low beams are dead and highs work when I turn them on.
tenhurst
2010 1500 sport
are you using an error cancelling capacitor?
bloombloom88
bloombloom88
Plano, Texas
Not that I'm aware of.. I have no idea what that is. This kit has worked flawlessly for the past 10 months until this morning
TheMaddog
DFW
Check grounds, check where the headlight ad the hid harness meet to see if that came loose.
But you say the highs come on. It must be that connection I just mentioned. Make sure that's tight, happened to me too and that's what it was.
bloombloom88
bloombloom88
Plano, Texas
Ill check that tonight. What does the relay do and how do you know if it's bad? And what causes it to fail?
TheMaddog
DFW
Well, if you can wiggle it around, it's loose. Make sure the little pin thing is pushed in and then it shouldn't move anywhere.
bloombloom88
bloombloom88
Plano, Texas
Ok I'll take a look at that too. If that checks out then what's next? I really need these working again by morning.. So if anybody can suggest what to look at that might be the problem please throw something out here so I can look
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
D'oh! On issues, please send them in emails - I can get to them quicker and get 'em bounced over to the guys at RS if needed. ;)
Here's what I'd check:
resistor connections, wiring to from resistor, relay controller, corrosion, or wiring from factory mating plug to relay
Just make sure nothing has moved off, no corrosion, etc.
bloombloom88
bloombloom88
Plano, Texas
Thanks JJ. Ill take a better look tonight and report back.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
pop me an email either way man! I won't be around the computer until late.
bloombloom88
bloombloom88
Plano, Texas
PM me your email address
