Hid lights
Red 2012 Crew
Central Illinois
I just got a set of hids from hidkit.com it came with the harness with a relay but the directions said nothing about using the harness when installing them. I installed them without the harness just as the directions stated and they seem to work just fine, no flickering or anything. Wondering if anyone knew what the harness was for and how to install. Also the harness had no connectors that matched my stock headlight connectors. (stock connectors have 3 verticle spades and everything in that harness is horizontal.
Big Boi
S. Fla
Red 2012 Crew
Red 2012 Crew
Central Illinois
The harness i have has a battery ground cable on it, like i said the only connector that will connect to my factory bulb connection goes directly to my ballast. Doesn't power come from the stock light connector? Why do they also need connected to the battery?
Big Boi
S. Fla
Because sometimes the bulls don't get full juice. That's the problem I'm running into note. I'm ordering my relayed harness kit tonight.
Big Boi
S. Fla
Also, I had zero problems for the first week or two. Didn't think I needed the writing kit either..... Until now!
EJM05
Somers, CT
440 Big Block
yea make sure you use the harness and connect it to the battery and all that good ****. It will work or you may end up locking the ballast and you will be screwed $$
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
hidkit.com............who dat? ;)
Red 2012 Crew
Red 2012 Crew
Central Illinois
I got the harness figured out and put on tonight. They seem to work just fine but the relay makes a lot of noise when the engine is running and the lights are on. Is this normal or is something wrong?
Bigdaddy
2022 3500 Laramie CCLB
6.7L Diesel Cummins
My wife saturn make some kind of running noise and you will get that.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Amart
Halifax, Nova Scotia, Canada
4.7L Powertech V8
HIDkit.com...........bleh.
35W ECONOMY SEMI-SLIM HID KITS - Retro-Solutions Store
66.99 (plus shipping) - and they are made to work with your truck. No ******** harness from some company that doesn't know a Ram from a Volvo.
Thanks for the link! The stock bulbs on my 2012 duals are horrible. The light output on my 2000 Volvo was so much better. I'm going to install HIDs in the spring when its warm enough to work outside.
Are the bulb caps worth getting/ any good?
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
Don't get the capped bulbs in the headlights, only in the fogs (for our trucks that is).
The capping is only used for lights that don't have a defector built in (that little cover over the bulb).
Also - when you go to order, use code "jj" to get 10% off of applicable items. (unfortunately the economy kits do not apply for the 10% off)
Amart
4.7L Powertech V8
Awesome. Thanks man. I was looking at getting one of the nicer sets just to get a little extra life out of them.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
bingo! the lifetime warranty is a nice perk too. ;)
Just don't forget to select your truck in the options so you get the right harness. :005:
09SMOKINHEMI
TEXAS
man, where was this diagram when I installed mine???? :)
Big Boi
S. Fla
What sets Retro's harness' apart from the others out there. The Ebay seller that I got my hids from will sell them to me for $10 (normally $15).
