HID lights
JET
Arlington,Texas
1996/2011 Ram 1500 Sport
5.9 Magnum/Hemi 5.7
I got my HID lights about 6 months ago. 6k HID 55w now one of the lights has turned to a pink/red color. :Pshyco: I'm at a loss as to why this has happen. Anybody got a clue as to why this would happen to just one light. :hmm: The other one is just fine.
TheMaddog
DFW
The bulb has gone bad apparently.
Trupiano
Registered User
Hometown : Puyallup,WA Stationed : Little Rock,
2010 Ram 2500 6.7L CTD Crew Cab
6.7L CTD
Possibly the bulb. Sometimes I've heard the ballast can go bad and change the voltage causing the color change, but also heard the bulb can do this, and sometimes bad wiring overheating.
EJM05
Somers, CT
440 Big Block
Test the ballast out. Switch the ballast to the other side.
BigDogg795
Ronkonkoma, NY
I'm sure JJ will chime in soon also...but I'd also switch the ballast to test.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
looks like its covered!
You nabbed these from me didn't you? I can't remember! If so, hit me up - I'll find the invoice number (you'll need that for warranty stuff with Retro-Solutions)
THX
quietpeen
2021 TRX
Hellcat
did anybody mention that i could be a bad bulb?
JET
JET
Arlington,Texas
5.9 Magnum/Hemi 5.7
Finally had time to check everything and yep BAD BULB.:) Starts out white then turns almost a brite purple when fully energized.
So RMA for a new bulb.
joshhhh
