ExpressRules
- Apr 4, 2014
- 2,001
- 1,363
- Location
- Southern New Jersey
- 2019 Big Horn Crew Cab
- Hemi 5.7
The bins under the floor mats is what I'm talking about. Only the Crew Cabs have them. Both Crew and Quad have the under seat storage area.
ah, yeah i have them sitting empty. no idea what to put in them
I have occasionally put stuff in them and if ever on a long trip you could put ice and cold drinks in there...My 1500 big horn didn't have them because they only came in the Laramie. After I bought my 2500 I remembered that now I have a Laramie so I should have them but I didn't remember seeing them. That's when I discovered they don't come in the mega cab. I wish I could still install them. I asked the dealer and they don't do it so I suppose I would have to get a custom install. They just don't store enough for that expense.
If you use it as a cooler how do you drain the melted ice? Is there a drain at the bottom?
Sent from my Note 3 using Tapatalk Pro!
the inner part is removable
if you had to get some custom made i'm sure you could make them bigger and you could even make them cooled/heated just like those electronic coolers
If you're talking about the under mats storage they do come in the sport as well. As for draining, the liners lift out.
I'm not sure if some one has said this yet as 38 pages are a lot to go through. But on some of the 4th Gen rams with cruise control they should have a high idle setting.
With your vehicle running and in Park turn on cruise control then press and hold set for about 3 seconds and your vehicle should go into high idle.
I've also heard rumor that you may be able to increase or decrease it from 1000-1500rpm but I haven't verified.
Sent from my Galaxy S5... with correct text... using Tapatalk
The Charger has the same feture, atleast in '12s it will keep going untill you click it all the way either direction then back to center. Kind of anoying if you accedntly hit it.
This is a great idea.Too bad we couldn't separate the Hidden features into year classes, then we know which ones are functional for a specific year truck ( Example: 2011 and earlier: Hold Unlock on Fob to open windows ) Might take some time to get it properly organized, but would help 4th gen owners to know if it works.
