Hide A Way Help
mvfd474
Milton, WV
just ordered some hide a way lights and need some help figuring out where to mount them in the head lights any suggestions are a big help I have the dual bulb head lights with the separate high beam bulb
MPG LOL
Most emergency vehicles I've seen install the strobes directly under the low beam/high beam bulb. Gives the best reflection pattern and doesn't interfere with the pattern of the main headlight bulb.
What kind did you get?
mvfd474
mvfd474
Milton, WV
I ordered the feniex cannons and since they are designed to be a bulb replacement thinking about replacing the high beam bulb with them
Molon Labe
MPG LOL
oh thatd be ideal. do they have a high beam function to stay a constant ON when not being used for strobing?
much better idea than drilling into the light and getting shavings inside.
mvfd474
mvfd474
Milton, WV
Yes they do in the rest they will replace my reverse lights
Molon Labe
mvfd474
mvfd474
Milton, WV
Update***
I didn't replace the actual reverse bulb because I didn't want to drill out the 1/2" hole to 1" I mounted the hide aways below the reverse bulb there is noticeable flash in the front the lens lights up though at night not very bright the rear however are ignorantly bright
Molon Labe
geneseedennis
