hasn't yet. I figured if I put it tight to the bumper it should be fine.It will also help push the nose of texting Honda Civic drivers into the ground. ;-)
Looks like a nice project. Does it interfere with Parksense?
This is top shelf thinking. Simple, protects the hitch, helps scrub off departure rocks.
now, is it strong enough near the top to incorporate a shackle mount that wouldn’t interfere with departure angle? That would be the perfect combo.
In John Deere Green on a hot summer nightNice!
The whole town will "said" that it shoulda been red but it'll look good to Charleeeeene!
I would like to place an order!decided to make it adjustable so it will make a better step when not offroad.
Right? I’m seriously considering one of these now. The fact that it goes out just farther than the bumper is brilliant, that way the ledge follows the slider down, and the rear bumper “should” never make contact with the ledge at all.I would like to place an order!
No bender just welded.sweet. what kind of metal bender do you have ? i would of had to make a welded seam at the bend because ive got no way to bend it and likely not enough room in the garage for more machines
