Homebrew Water **** kit
fasthemiram12
Eagle 5.7 vvt
Here's a pic of my homemade water **** kit..
From right to left it is bulk head fitting to tap into factory washer fluid tank into -6 line to pump. Out of the pump comes -4 line that steps down to -3 nitrous line into a nitrous fogger nozzle. All activated by a wit switch on the pedal.
I'm gonna water pressure test it soon before it goes on the truck but I think its going to work out well with full adjustability going up and down with N2O pills.
Not bad for 150.00 worth of parts.
UNBROKEN
2012 Ram R/T
You should have a box this week with the check valve and some other little stuff in it.
I do hope you'll pay close attention to the spray pattern from that nozzle before you use it though. I have a feeling it's not gonna work right. A real water nozzle is only a few bucks though and you can put an AN fitting on it for your hose.
fasthemiram12
fasthemiram12
Eagle 5.7 vvt
I just received the stuff. Thanks
