Hey has anyone had any issues with the hood decal coming off? On my 17 PW I have a couple spots that the decal has just come off. The truck is still covered on the 3 yr / 36K warranty. The dealer originally said it was covered then a month later I am now being told it's not covered.
One of the leading causes of vinyl graphic/decal failure is winter weather. Not because it is cold and snowing outside, but because of what comes with it being cold and snowy.
In the winter, there are winter pollutants than can build up over the surface that can cause potential deterioration. In addition to that, there is also the salt and other chemicals placed on the roads that will build up on and deteriorate the decals (especially flat surfaces such as the hood), and even do a number on your paint and undercarriage. It is recommended to wash your vehicle one every 2 weeks or so to prevent this type of damage in these conditions.
Regardless, the warranty work may be done by your local dealer, but it is ultimately not paid out by them. So either they are lazy and just wanted to find a way to deny it, or they have a very legitimate and proven reason to deny it; which they would then be responsible for explaining such reason to you and in detail with the evidence to support their reasoning.
To even state the above information regarding degradation of vinyl in such circumstances is not reason enough. That is called speculation. And it is not your position to prove that anything they mention couldn't have caused the failure or damage, instead, it is their position to not only state what did cause the failure or damage, but then to back this up with hard evidence to prove what they claim.
Write a bad google/yelp/facebook review on the dealer. Add your story and inform that you will be submitting a report to the BBB and filing a claim with the FTC. Call the dealer and speak to the supervisor.
Do this, and they will not care so much to disregard a simple $200 - $300 decal replacement (your cost....their cost would be less); which wouldn't really even affect their bottom line as it would be Mopar Warranty.
However, even if that dealer refuses to do anything. Go to the next dealer, explain the situation and the actions you have and are taking. And they won't give you the same problems.
But don't take any reviews down unless that dealer absolutely makes it right. And if/when they do, then you can "update" the review to still show how it started but to include how it ended and the results of it.
