How Do I identify gearing? 1996 1500 Magnum 4x4 V8
fidelityflip
Knoxville
5.7?
Hey Guys, My son lost the carrier on his rearend, and We are looking at just finding a used rearend to swap in. He has kind of been managing this on his own as I was out of town, so I am scant of details. He says there was a bolt tag on the rear diff cover but it did not identify the gearing, and he could see nothing on the door tag to indicate gearing, but I just dont know enough about Dodge pickups to know if he missed something or where to look. I see there is a 3.55 and 3.90 gear option for this year when I look on Car-part.com. I know in other trucks I have owned the two gear options would be related to manual or auto trans, but not sure if that is the case with dodge. He has an auto trans. The truck is at his house, so I am trying to get some early info before I get more involved in this. Thanks all.
Riverside California
2018 2wd
HEMI 5.7 Revolution 4.88s
You might be able to find a tag on the differential housing cover itself if it hasn't fallen off ... you can also open up the diff and the ring hear will have it stamped there too ... or the glove box, you can find a build sheet sticker ..
But these trucks almost all came with the 3.55 from factory, there were some with the 3.92s ..my pops first Magnum came with the 3.92s and it was 4x4, mostly the 2wds will come with the 3.21s for those years ...
F
fidelityflip
Knoxville
5.7?
Thanks, we will check it out. He said the tag on the rear diff didnt show gear ratio but maybe he misread it.. :cool:
GTyankee
El Cajon Calif. 92021
3.0 ecodiesel
If the rear end will rotate, you can use some tape to mark your tire & the drive shaft, after raising the vehicle just off the ground
ratios were
3.55 or 3.73 axle ratios
2018 2wd
Boom! that's another good way ...
F
fidelityflip
Knoxville
5.7?
So he did find a tag that says 3.5, not 3.55, just 3.5. Should we assume it is infact representing a 3.55? We cannot spin the rear as it is jammed up. I dont think he could see a ration on the ring gear.
Nealuss
5.2L 318
Yes, that would be the 3.55. If everything is original you can also look on the sticker under the hood. Right by the latch there is a basic options list that will show the factory equipped differentials.
18CrewDually
U.S.- New Jersey
Cummins 6.7 H.O.
If it is all apart, count the teeth on the pinion gear and ring gear. Divide the ring gear # by pinion # and that will give you the ratio.
For Example:
42 (ring gear) ÷ 12 (pinion)= 3.50 ratio
NJMOPAR
Older and faster
ELizabeth, NJ
If it's 4WD wouldn't the front diff have to be the same ratio?
May be a tag on that.
Some models had a paper wraparound on the right rear axle tube just behind the backing plate, could look there too.
