- Mar 12, 2017
- 557
- 537
- Location
- Washington State
- 2013
- Hemi
If you don't care about the technical, or don't want to give yourself a headache trying to keep pace with the following explanation, skip to the next post.
Anyone who chooses to follow along below, will need to read carefully, and look at each part as its called out, in order to understand.
Reference the linked PDF for part numbers, descriptions and a schematic. https://marketing.transtar1.com/acton/attachment/18758/f-147c/1/-/-/-/-/BW4444 Flyer 0917.pdf
The arrangement of the ballramp (Borg Warner calls it the mode hub, part 35, 814 and 619), is difficult to visualize and even harder to explain. But im going to try here. If I do a ****** job of explaining, please forgive.
The transfer of compressive force from the ballramp into the clutch plates flow as follows. I know its complex, but if you print the .PDF so you can look at the arrangement of parts as your reading below, it'll be easier.
When the mode hub magnet (part 910) is energized, the magnet exerts a very soft (read 12 volts, 5 amps) rearward (towards the rear of the truck, to the right hand side in the schematic) pulling force on the mode hub (part 35), which transfers it's pulling force onto the thrust bearing (128), which then transfers the pulling force onto a shim (part 221), which then transfers the force onto the circlip (407), which then transfers this force onto the shaft (part 2), The pulling force on the shaft, then transfers through the shaft, back up towards the front and onto the drive sprocket thrust washer (part 237), then through the thrust bearing (part 126), then onto another trust washer (part 237 again), then this force is transferred onto the drive sprocket (part 38), which in turn, transfers this force into the clutch basket (clutch pack kit part 625), and terminating in the clutch friction/steel plates (parts 813 and 812)
The other portion of the ballramp (part 619, cam, magnetic), applies the other half of the force, which compresses the clutch pack. It does so in the following way.
When the above mentioned mode hub is activated, and applies its rearward force through the shims, circlip, shaft, thrust washers and bearings and into the clutch pack (outlined above), the other half of the ballramp (part 619) applies this magnetically created small force, in the opposite direction, forced forward (towards the front of the truck) by the balls inside the ballramp. (part 619) applies its force against the armature (part 630), which transfers this force into the "apply plate" (part 621), which in turn transfers this force onto the clutch friction and steel plates (parts 813, 812).
If your able to follow the transfer of forces listed above, you can clearly see that the rearward pressure 0n the clutch basket, which is free to slide on its respective shaft splines, is met by forward force applied via (part 619), through (part 630 and 621), into the clutch pack (parts 813 and 812). This creates friction inside the clutch basket.
Now, in this activated state, any time the rear wheels attempt to turn without the front wheels turning along with them, the 2 halves of the ball ramp (parts 35 and 619) attempt to rotate in opposite directions, and the balls force the 2 halves apart and apply a huge compressive force onto the clutch plates (parts 813 and 812). Recall in a previous post, I calculated that for every 1 foot pound of torque the engine sends to the transfer case, there will be 24 lbs of compressive force mashing the clutch/steel plates (parts 813 and 812) together.
Also, keep in mind the shape of the ramps. If you stop and put the truck in reverse, the front half of the ballramp (part 619), reverses direction, the balls roll into the deeper part of the ramp and the front wheels are freed from their locked (clutched? "choose your own term") state, until part (619) has rotated 120 degrees, and the balls are forced up the other side of their respective ramps, after which the front/rear systems are _re-coupled_. ( I don't wanna get flogged for saying locked!)
So, you can clearly see that powering the magnet (part 910) pulls the clutch plates together with a small magnetic force, creating friction. You can clearly see that once this friction is initiated, any relative rotation differential between the front/rear drive systems will cause the ballramp halves to rotate in opposite directions. Once the ballramp halves have rotated in opposite directions 60 degrees, the balls force the clutches into compression with about a 24:1 mechanical advantage. Every 1 ft lb of rotating torque creates 24 lbs of axial force into the clutch plates.
This is how it works. This is whats going on inside the transfer case. These are facts, and they don't care about anyones preconceived notions.
if you ever decide to fix it yourself or hire a mechanic to tighten things up. Pay attention to the next post.
