How donI remove this Stupid thing
CoCaDoRi
North Dakota
Trying to replace the poor excuse for a mud guard on my 3500....
It has this plastic thing... I don’t wanna yank too hard for fear of damaging the fender flair...
How the hell do you remove it???
duckman631
New Jersey
2016 Big Horn Crew Cab
Hemi 5.7 K&N Cold Air Intake.
I feel for ya. I hate that it seems every time I go to do something on the truck, I always get a curveball. They can’t make anything easy. Personally, I would be pissed as soon as I realized I have no idea how to get it off and cursing the fact they couldn’t have just used a regular fastener and I would pop it out with a screwdriver and probably screw it up . Good luck.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
3.92 8 Speed 5.7 4X4
Screw head broke off, it’s plastic so drill it down about 1/2”
C
CoCaDoRi
North Dakota
what looks like a screw head is actually plastic... there is one on each mud guard two have the nub sticking out and two are flush.... what is on the "other end" of this - is it all plastic?
C
CoCaDoRi
North Dakota
Oh I cursed alright... pretty sure the neighbors are blushing...
I didn't wanna pop it with a scre driver fer sure... the thing is in there and but good.... a happy camper I am not....
buddy guy
alberta
I'd slip a cutting knife blade under the edge and saw through it. and replace with original or aftermarket plastic plugs. there's a ton of them available at hardware stores..some that are better than the oem. I like the GM type where you pull up on the head with a screwdriver blade and that frees the base part to just slip out. I just had my door panels off to do the speakers this week and the screw type are for the birds. In a perfect world, tney unscrew and you pull the bottom out. Or they just turn and turn and turn, unless you also put a straight edge underneath the screw part to give the screw some additional leverage against the threads. I had a mix of both in terms of how they came out. mostly the latter.
slinghigh
southern cal.
your going to want new fasteners.....use a plastic fastener removal tool ….it will go under the fastener and lifts it out and will probably break...your new mud guard should come with fasteners if not you can buy online or your dealer ….good luck...ps I have used a fork many times for a removal tool slide the fork underneath the fastener centering the fork so the pin of the fastener slides into middle of fork..
C
CoCaDoRi
North Dakota
Brilliant on the fork idea....
Thanks!
The new “heavy duty” flap come with metal fasteners and brackets
buddy guy
alberta
that's Forkin' brilliant!
(i'm here all week:banana-mario::biggun:)
raff18
Sudbury canada
2019c
Yup that’s a plastic rivet. Use a drill the size of ¼. But make sure to hit the center bang on. Don’t go too deep either as u will hit paint.
duckman631
New Jersey
Great. I’m doing my speakers next week. Can’t wait to see what happens
buddy guy
alberta
just don't expect them to screw out without an assist. put the screwdriver blade or tool just below the screw, not between the panel and the piece below the screw. i did that a few times and wrecked a few fasteners in the process. it didn't help the door panel wasn't on quite right (off center of a few holes) as i didn't realize that you should remove the bezel ki the panel that fits around the door handle otherwise you fight with getting the panel back on. the wrong way is possible but takes 30 minutes and a lot of cursing. the right way, the tabs just drop into the slots. lol
Marshall
Sk, Canada
2014 sport
No screw head, these are plugs, But I am thinking drilling the center out may not be a bad idea, as if you just pry them out they are buggered anyway, Body shop guys here , pipe in. you have to make new plug up of course.
Tim Garceau
Banned
Eagle River
2014 Sport Quad BSP
Yep, either way if you try prying that out it may enlarge/distort the liner hole so just remove/drill the center portion that acts like a mandrel and backs up to squeeze the flange.
Rivet is junk anyway, don't compound the damage.
Runaround
Silsbee
Most auto parts stores carry many different types and sizes of the plastic fasteners. Drill it out.
TomB 1269
Schenectady NY
2019 Classic
FYI, Lowes carries a pretty good selection of these and the screw head type. I was actually impressed as they had more than advanced auto on the shelf.
