Snacktime
I would spend some money on a wide angle back up camera for the trailer. You will need it if your married and want to stay married. Rear air bags, you can use them to help get unstuck by lifting and lowering you rear (longer the trailer the more you will drag it). Look into a couple of 2"x6" by 4-6ft boards for using for odd things (I use to put one on the ground next to where I want the trailer tires to give the wife a visual). Harbor freight trip to buy tools, 12v air compressor, a good battery booster pack, jack for the trailer and extra hub/wheel bearings/brakes(not having to go find the parts can save your trip).
Different between a ram 1500 and 2500 are 2000lbs of vehicle holding down the front of the trailer. Driving slower give you less weight transfer when you hit bumps. Weight helps control the trailer, you have less. Knowing when to park if its windy! If it is high winds and semi trucks are pulled off the road just stop. This includes high tail winds and front winds. I have personally picked up people who have had there trailer rolled over in the wind.
You have enough hp and brakes to do any major highway. Its the small back roads that will get you. Learn to watch for the yellow signs with restrictions for semi trucks/delivery trucks. If it turns into 1 lane find a different route. Stay on pavement!
Go watch Matts Offroad Recovery on youtube, you will see how little it takes to stop a trailer. Watch the turning radius needed to get people out and the value of a kinetic rope.
