billdozer79
At how many miles did you start using synthetic oil? I'm sitting at 62k right now and am thinking of going that direction.
I run regular oil in the summer and synthetic in the winter so the motor primes faster in the cold. Motor still running great at 250,000
Summer usually in the 15C to 35C range. Winter usually between -10C and -30C. 2011 ram 1500 with hemi and 3.92 gears. My 2017 is still sitting in the garage. Might start using it in the spring.250k on what truck/motor combo? What are your summer/winter temps?
I put a line on my filter with a sharpie so once it touches I can see that I gave it a full turn. I've had a couple leak so now I make sure. I can usually get 1 full turn with just my hand as long as I kept the new filter somewhere warm before I changed it. It is a bad design for making a mess though. I wipe it up best I can and then use brake cleaner to get rid of the rest.Just did the first oil change at 3050 miles. Put in Quaker State Ultimate Durability Full Synthetic. Used a Fram Ultra filter, what a PIA. They have that damn thing right above the power steering and frame cross member, BAD design. I wrapped the power steering and frame with plastic to keep it clean and give the oil something to flow around into the pan. The Fram Ultra got good reviews but I don't like that none of my oil filter sockets fit tightly. I managed to get 3/4 turns once the gasket touched (says 3/4 to 1 turn on filter) but I found with my Jeep GC that you best get 1 full turn or it may leak. I like to use the cap sockets and go 1 exact turn, hopefully hand tight will do. No leaks after a short drive. I feel better going through the winter with synthetic versus the synthetic blend they use from the factory.
