how much cfm?
ram15
Mendocino, Ca
I've been looking around trying to find a e-fan but I'm not sure how much cfm I'm gonna need. I live on the coast but sometimes I go to the Sacramento valley which can get into the triple digits. I found a kit on eBay that claims 5000 cfm. Would that be enough, I'm not sure how much my 360 needs.
Graygoose
Indecisive Car Owner
Oklahoma
Convert, for now.
small
the most the better, but look at amperage pull, that will be your issue.
R
ram15
Mendocino, Ca
the ones im looking at are 11 amp pull, is that too high for fans.
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
3000+cfm should be good. i am running 2 fans with a total of 4600cfm. thats way over kill. but boost makes me run a little warmer than most.
R
ram15
Mendocino, Ca
talon6
ohio
2002 QCSB 4X4
supercharged 5.9
if your radiator is the same as mine, i doubt you will be able to fit 14 inch+ fans. the biggest i could fit was 2 12 inch fans.you might want to do some measuring. i made a custom shroud for mine. you get the best pull from efans when they are a couple inches away from your rad and in some type of shroud.that way they draw air across the whole rad instead of just where the fans are.
and watch out buying no name brand fans. the motors wont last you very long. i am running permacool fans. flexalite makes good ones too. thats just a couple brands that i know are good. sure there are others.
Hotroder383
Washington Mo
318 or 5.2 which ever you want
