How To: Add Factory Keyless Enter N Go
BZ2500
Belize
6.7 cummins
I wouldn't mind trying but when i pull up the info on the hub it says pin not programmed.
Mordechai
St. Pete, Florida
Required time delay means you have tried too many times with an invalid key.
I used the 4 digit code I got from my dealership to program the key. 0000 was just used to reset the hub
My RF Hub part number was 68363199ac. With everything working now it still does not say pin programmed. Just VIN
Sent from my ONEPLUS A6013 using Tapatalk
BZ2500
Belize
6.7 cummins
My hub part # is the same as yours, 68363199AC. I'm running out of ideas now..
Mordechai
St. Pete, Florida
I don't think it would hurt to stop by the dealership. Just to eliminate that.
https://w06.dealerconnect.chrysler.com/parts/keycode/policypdf/en_US/Key_Code_Policy_en_US.pdf
I'd print that out just in case. Go directly to the parts department. They are usually much easier to work with. Don't need to tell him the whole store. Ask for the 4 digit PIN for key programming.
Worst case you may need a new key, it's possible you got a defective unit. Though it does look like a pin issue
BZ2500
Belize
6.7 cummins
Problem is that im In Belize, so i just cant walk into the dealer.. I was there last week buying my parts. I might try and call and see if they can do it over the phone..
It does seem like a pin issue, i just dont understand how it changed from the last time i reset the rf hub..
Jimbodio
Olympia, WA
I have started collecting the parts to do this mod and today I received my parts from Mauser. I find that the connectors aren’t fitting the antennas. I confirmed the correct part numbers were ordered according to the post. Is there a modification that needs to be done? TIA
J
Jimmy07
Can you post a pic of the connectors you got. I actually just got an order from mouser, and two connectors were wrong. I ordered 3 pole connectors, but received 10 pole connectors, even though the label on the ziplock bag had the correct part number for the 3 pole connectors on it.
BZ2500
Belize
6.7 cummins
Dealer was kind enough to provide the PIN.. Too bad its the same one I've been using all along.
Any other suggestions? Should i try the pin puller app?
chrisbh17
Honestly my next suggestion would be to try the Android version of the app but I know that will cost $$$ and time.
Maybe contact the developer and explain what is going on.
J
Jimmy07
The chances your PIN is wrong appear to be slim to none. I’m not sure if anybody has done this on windows version? Like suggested, email the developer. First, turn on the debug log, try everything again, and send the log along with an explanation of what you’re doing.
BZ2500
Belize
6.7 cummins
Yeah that's a oood idea.
BZ2500
Belize
6.7 cummins
Anyone have another email for the developer? I already sent one to the info@... but remember that he didn't respond to that when i requested the activation..
1500ram12
5.9L Cummins
You'll have to be patient with him. He deals with a ton of emails and request. He's also in Europe so there is that delay. I'm sure just some emails get lost or overlooked.
2018 2500 6.4L Tradesman
BZ2500
Belize
6.7 cummins
He just got back to me.. I just thought the email was one he didn’t monitor.
Austen
Missouri
@Jimmy07
Do you happen to know what I need to ground and how to do so in order to bypass installing a hood latch assembly for OEM remote start? Truck info should be in my signature. I'm wanting to add the OEM remote start and my local dealer has the kit in stock but I figured if I could just by a key fob or overlay for my current I could just program with alpha and not need anything from the kit.
17' CCSB 4X4 68RFE 2500 6.7 Tradesman DRP EGR delete, CTT tuning w/TCM tuning, UAQ w/7 speed HVAC, 7" premium EVIC, OEM front Parksense, OEM style front camera, aux switches
Jimbodio
Olympia, WA
Jimmy, I’ll get pictures of the connectors tomorrow and post them. I’m going to order the connectors from Nexus next. Slow process as I’m doing a bit each pay day for all new parts. The hard parts are no worry, just all the connectors
Alexx
Los angeles ca
@Jimmy07
Pin 11 bro ive done many nd my personal truck has it also nvr had a problemd46eaf3786215d917e05a9e5d7e9970d.jpg570104391d10cef5adba5d83899ec9bf.jpg
BZ2500
Belize
6.7 cummins
So just heard back from Alexxy, and he says that for 2018 FCA changed some stuff around with the security. He's gonna try to find a fix for this but for now i cant complete this mod. So anyone out there with a 2018 wanting to do this better hold off.
Jimbodio
Olympia, WA
Jimmy, sorry I’ve been busy. Here are pictures of the connectors. They just won’t plug in to the antennas 06F05EA0-90AC-4D8E-A4A3-7B32EC5D9A57.jpeg1206BA35-5DD2-4DF5-A79E-6A4E4531606D.jpeg7831F58C-1ED9-48CC-A710-5BE8C01E2948.jpeg
Ftank
