How To Add rear Park assist
fofonta
Dodge SPORT
5.7 HEMi
Hi, I would be interested in buying your wiring harness. Is it possible to send to Europe?
I have a Dodge Ram 2013 sport and I would like to finish the rear park assistant I have already ordered this:
1EW63TZZAA 4x sensor
1JK73RXFAA 4x sensor holder
68031820AA 1x cable harness
68139116AC 1x module
if i have your wiring harness i should already have everything to plug in is that so? Thank you
Buckeye2019
2018 Cummins
Has anyone ever picked up the push button and the two key fobs from a salvage yard and did they work?
S
skuppy069
canada alberta
2018 1500 cc
I think if you got the rf hub and the original keys then it should work .
The only thing is getting the 4 digit pin for the used rf hub
S
skuppy069
canada alberta
2018 1500 cc
If those keys are used and you don’t have the rf hub that they where married to then I think those keys won’t be any good .
The KIN(keyless ignition node ) will be good to use
Buckeye2019
2018 Cummins
So the Ed is the one that goes in the back wall right?
Buckeye2019
2018 Cummins
Does anyone have a part number for the park assist module for a 2018 2500 for the front and rear
Djam
California
Ecodiesel
You guys have really done a deep dive on this. Hopefully this is a quick question. I have a 2017 with factory rear parksense, trying to add the front. I put on a full bumper with sensors, and my truck had the wiring in place to plug in the front sensor harness. Under the dash I’ve swapped my rear only module for the fr/rr module, but dont seem to have the 3rd plug for the front sensors. Is it hidden somewhere, or do I need to add it in? How would I go about adding it in?
SHERMAN ROBBINS
Dallas
The new module should have a place for the plug if you go back and look at my post #158 it shows a pic of the new module. Never mind my reply I read your original post wrong.
SRich2015
USA
I’d look to see if the plug is taped up around the module somewhere.
Djam
California
Ecodiesel
Resolved - my 2017 ram 1500 (canada market) does in fact have the wiring in place to add the front parksense. My truck has factory rear parksense, and I had the dead end 8-way connecter up by the front bumper. The 3rd blue connecter was not easily visible, but moving the ebrake cable and rolling the carpet revealed the pigtail along the floor, running up towards the brake pedal.
Dash switch and module are on order.
I know its an old thread, but my thanks to all of you trailblazers on this one.
the_nid
Bristow, Virginia
3.6 L V6
I have a question about sensor power supply. I bought the park assist module (its for both front and rear) which came with pigtails (plugs and wires cut off at about 3 inches). Looking at the wiring diagrams my understanding is that the sensors get power from the park assist module itself, i.e. the 'pk/yl' wire fed from the run relay. Is that correct or do they need an independent power source? Also, where do I get the run relay power from to connect to the pk/yl wire on the pigtail?
Thanks in advance!
S
skuppy069
canada alberta
2018 1500 cc
Thanks in advance!
The sensors get there power supply from the park assist module itself .
The run relay circuit can be taken from a switched power source .
If you are running wires and making your own harness then I would just take power from the inline tailgate connector .
If you read the first few pages of this post I think showed some pics of the inline tailgate connector and the wire counts etc .
If you need any more help let me know .
Cheers
Buckeye2019
2018 Cummins
Just finished mine up tonight works great. Y’all need to give skuppy069 a big welcome. You know he puts a lot of time and money into this mod. I just want to say thank you!!!
S
skuppy069
canada alberta
2018 1500 cc
Thanks for the feedback bud .
Glad you got her all done .
What’s your next mod going to be ?
Cheers
the_nid
Bristow, Virginia
3.6 L V6
Cheers
Thank you! I'm still waiting on a few parts and so haven't take a look at which (if any) harnesses I have in the front or the back. Do you happen to know the part number(s) for the front harness jumper connector(s)? Meaning, which connector would I use to interface the the factory front sensor wiring with the park assist module, the 8-pin male connector?
S
skuppy069
canada alberta
2018 1500 cc
I think so far the front connector has been determined not available if I read through this thread .
I don’t know the part number for that part .
OasisNinjaBat
