how to get 8'' drop on the back ??
08redbull
need help what do I need to get 8 inch drop on the rear , i already have flip kit , drop shocks ( street performance shocks) , and 2'' drop shackles . ?
usaf2006
North Carolina
You could put 2" blocks on the springs. Not sure how recommended it is, but that would do it. Just like 2" lift blocks, but in reverse! :)
Pics of your rig too if you can.
08redbull
I was thinking on doing that and install some shock extenders if that's what they're call , and how do I add picture's ? I'm new to this lol ?
08redbull
xb1230
Hobby Mechanic
South Shore of Montreal, QC, Canada
Go into your User Profile. Then create an album, load the pictures in the album and you should get the BB code for the pic to post back in here.
With the setup you are looking for, you may consider a "C" notch on the rear frame as chances are good your truck will bottom up real good and often. Some kits come wit the notch plates included, but they are usually easy to make yourself if you are a little handy and if you have good experience in welding, and I insist with the welding part as your truck will hang on those welds. If you don,t have appropriate welding knowledge, get a pre-built "C" notch. It will be much safer.
08redbull
i already have a cnotch i forgot to add that . i was just wondering on how to get them 8 inches since im wanting to go lower currently have 6'' rite now
usaf2006
North Carolina
If you click on "go advanced" underneath to the post box here, then you click on the paper clip and upload a picture, if you can't figure out the album. Are you 2wd or 4wd? Not many lowered 4x4s on here, but I'd like to be one of them.
ST-8
Flip,shackles an a 1" block should get you 8" in rear
