Texasez
I did the zip tie method. I jacked mine up to give me a little extra gap in the springs. Pretty easy. Just had to run the lines. No squeaking on mine yet. I'm running them at 20psi since we are traveling and have the back full.
Didnt even takeshock bolt out jack the frame up until back tire is in air a little than remove black knub on top of bag flatten bag put black knub back on slide in coil and up than grab another *** and coke after all said and done switch to nextside
Sent from my GT-I9100M using Tapatalk 2
Has anyone installed the airlift 1000 with a rear coil spacer?
i just ordered a set and was wondering where you guys all put your valve stem at? i dont wanna just drill a hole somewhere and would also like to be able to reach the valve with a little 12v air compressor i have. pretty sure the cord wont make it to the rear bumper so i was thinking maybe in the fuel door or is that a bad ideal?
Cool beans.
Why not install the 'T'? If one side fails I don't want the other staying inflated. Can't think of a practical reason for needing to balance a load.
