How to install Morimoto Projectors in your 02-05 Headlights
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
So, I've got a writeup for the 4th gens...........time for the 02-05s!
Items needed for the install:
  • Headlights!
  • Morimoto Projectors
  • Shrouds of your choice
  • BiXenon HID Kit
  • Quick Disconnects (2 sets), might not be needed.
  • Oven
Headlights (clear corner lights purchased from eBay):
Projectors and Shrouds (Gatling Gun):
BiXenon HID Kit:
Get ready to bake fellas! (only time I use the oven) :D
Check lights - kinda weird, this one had syran wrap under the lens (they cover the lens with syran wrap.......somehow this one had it under the lens!) - make note so you can take that out later.
Bake. I baked these for 6 minutes at 250. There are 3 tabs on the top of the headlight, 2 on the bottom and one on the inner (grill side) of lights. After they come out, use a flat screwdriver to lift those tabs up, them pry the lens open. Pretty quick on the 02-05 lights. Be sure to wear some leather gloves, don't want to burn your hands! When its done - here's what you have:
Lens and Bezel (as I wasn't painting this set, I left them intact, no need to separate):
Headlight housing:
Remove the thing that covers the bulb, few wiggles and its out.
The Morimotos are a bixenon projector, so they have a solenoid that controls the cutoff shield. That solenoid has 2 wires, those need to find their to the back of the light. Easiest way - drill a hole. :D I used a 3/16" bit, picked a spot in the middle of the flat spot where the bulb cover thing slid into. Slide your wires through that hole.
Hey, new parts! Yeah, I missed a pic - the projector is installed in the pic. Here is is from the front. I put blue tape over the projector when I work on them - don't want them to get fingerprints and crap on 'em.
In your kit you will have a rubber o-ring. That slides onto the shaft, then you install the Morimioto projector into the housing. On the back side, slide on the 9007 adapter, then the nut. Use a pair of needle nose pliers to tighten the nut. Next, install the bulb holder. 3 screws, done. Watch the screws.......the heads are very weak and they will round off FAST. Trust me.
Projector installed:
Install the bulb:
Slide the shroud into place
Install some sort of quick disconnect wires on the back of the solenoid wires. This is the 3rd set of Morimotos I have done, and the first 2 came with a connector..........these didn't. Unfortunately.......I didn't keep the ones from the first sets (which I cut and hardwired - different setup on those though). Anyway, I got 2 sets of disconnects from Radio Shack for less than $5.
Don't forget to change the wiring on your harness to fit the quick disconnects (again, if needed).
Take the lights out to the truck, aim them as best as you can (you can adjust them more later - no biggy, just get 'em close for now). Make sure the lights work, all that jazz.
Head back in, time to seal it up! As these lights were brand new and the glue seemed very pliable, I didn't remove it all to install butyl tape. I removed the bulbs, popped 'em back in the oven for 4 minutes and reinstalled the lens. Get the clips back on while its still warm! I then put some butyl tape around the hole I drilled for the high beam wires, don't need a place for moisture to get in!
Take some time to take some pics!
Installed pics will be added later, after the customer gets them in!
OklaHemi
new age hemi
so no cutting necessary? that is an awesome write up jeremy. could you post a link to the morrimotoorare you going to start to distribute
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
No cutting, just one hole drilled. So, really - if you wanted to take these out later.......you could. Well, if you don't throw away the spare parts!
Here's a link to the Morimotos:
3BSpec: Morimoto Mini Bi-Xenon Projectors, 2.5-Inch
thats just the projectors, still would need shrouds, and a bixenon hid kit.
Bad Habit
Land O Lakes
Modded 4.7l
sweet write up maybe when i have extra cash to do something like this i may, but for now i got other stuff thats in my way to get done but this def will be added to my list.
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
Thanks guys!
Cracks me up........I was yakkin' with a friend last night, showed him the thread - he asked me "why the fukk would you post this up? That will hurt sales!"
LOL - Some non forum people just don't get it.........its not always about the almighty dollar.
Anyone need some WAX? :D
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
So your the lucky guy he made them for :005:
Just think......if I did a set for you, all TOTM contenders would have modded headlights! LOL :naughty:
shadow11
Banned
Houston TX
I would love for you to do a set for me! It's just I don't have $500 laying around or I would have. lol
0212353
Vendor
Preferred Vendor
Florissant, MO
2x 5.7L & 6.2L
OklaHemi
new age hemi
nice rus those are going to be bad ass on your rig.
