How to install Morimoto Projectors in your 4th Gen Headlights
14MDRam
Rising Sun, MD
So the Minis are able to do both high and low beams? Am I correct in assuming that it is in low beam by default? If you were to install with a non bi-xenon HID kit would you have any issues? I'm assuming you simply wouldn't hook up the two wires coming from the projector.
0212353
Vendor
Florissant, MO
2x 5.7L & 6.2L
minis won't fit in the highs........well, the shrouds won't, not easily.....
The projectors are low beam by default, and the kit has to be a non bix kit - you tap the inner wires to the highs for your solenoid drop on these.
WilliamS
Tampa FL
So with these using the stock bowls to attach I assume the headlight adjuster still works to aim them?
daveray9
Great write up!!
Anyone looking I got a set of quads for $100 plus shipping.
Sent from my SM-G920V using Tapatalk
Marty424
