HVAC stuck on Floor Board
Scott D
OK
Trying to Diagnose my HVAC System. It seems to be stuck blowing on the floor. I do get heat and cold air just 95% of it coming out of the floor. I took the control switches out and seemed to hear suction. I think its called a actuators that im seeing move. There is one thats behind the cup holder closest to the floor in the center that i dont see move when i switch the controls. Limited on the knowledge here. Any suggestions to start to diagnose? on the outside i see a small hose that goes across my engine and links up to my battery thats clipped for some reason...
2001 Ram 1500 5.9L
Dodge 1500 4X4
Rochester, NY
Is that a vacuum hose going to anything if not supply it vacuum, your actuators and blend door are vacuum operated, Maybe one of the actuators are bad, or blend door actuator.
Austin-591500
Eastern US
2001 x2
5.9 Magnum, 5.9 24v Cummins Turbo Diesel
check blower motor transistior, might be called something different but mine did the same thing
MIchael JV
Mississippi
Diesel Cummins 24 Valve
I had a problem with blower only blowing out the top (defrost) and cruise control not working, found vacuum leak repaired same everything is working as it should
