Belgiquebasterd
- Jul 12, 2011
- 111
- 24
- 2003
- Inertia 392
Ran into a problem installing my Hydroboost setup on my 2003 hemi ram. I'm missing a final connector to connect the pressure line. Problem being, since I live in Belgium no one has any of these US size connectors in stock so I'll be ordering one online, could someone identify the type and size of the connector I need so that I can order the correct one? Cutting the line and putting another connector on it won't work since no one hast the tools to work on US size pipes, everything is metric over here.
As you can see I'm left with two male hose ends, so I need a double female connector to hook them up. For those not familiar with the hydroboost setup, the size of these connector is the same as the connector that goes from the power steering pump into the steering rack on a stock Hemi.
Edit:
I checked on the rockauto website and it gives this description: Pressure Line Assembly; 16mm Female O-Ring x 18mm Male O-Ring x 37 1/4", so I'm guessing I need a female to female 16mm female O ring connector, is this correct or do you guys call it something else?
Edit:
