I wanna know everyone’s thought
Dusty
Rochester, New York
Mate an LS to a 545RFE bwahaha....unless you're changing the trans too.....? And then the entire control system? And then....and then...
Actually, there's a local fellow who is running and 8HP75 in his older Silverado.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 153715 miles.
HemiLonestar
Navy Badge Coast Guard
MD
Regards,
Dusty
That's a different story. I'm betting he still has the Chevy engine in it.....? Didn't try to run a hemi in the GM architecture?
The ZF is ridiculously easy to retrofit into anything. With the TCM in the valve body all you have to do is give it the inputs it requires after mounting & driveshaft/t-case arrangement. I've seen an 8HP70 hooked to a LA318 2 bbl and I've seen a big block Chevelle with one.
Dusty
Rochester, New York
Yes, he still has the Chevy motor.
Regards,
Dusty
2019 Ram 1500 Billet Silver Laramie Quad Cab 2WD, 5.7 Hemi, 8HP75, 3.21 axle, 33-gallon fuel tank, 18” wheels. Build Date: 3 June 2018. Now at 153848 miles.
Arturo Rojas
