I want to swap my gears. 3.21 to 3.92?
crackerjack1957
2014 Sport 1500 CC 4x4
Hemi 5.7...65RFE...4.56
I would go with 4.10 also....mileage will improve in city....I did 4.56 but have 35 inch tires & 6-speed trans. Mileage improved from the 3.55 that was always lugging engine & dropping to another gear.
Crazygrady1948
Hi. I have a 2014 Laramie 5.7. Is there a way to tell what gears I have? I bought it used so I don't have any of the original papers.
Thanks
Thanks
Crawl underneath and look at the drivers side axle tube,there should be a sticker on the bottom side of the axle tube with the ratio listed.It'll be in small writing,and might not be legible anymore,but worth looking for it.If not any dealer can run your Vin number and tell you what gears you have.There's sites that'll also let you run your Vin number on,and they'll give you the info to,but off the top of my head I don't which one.Somebody should chime in with them soon though i'd expect.
Guy lIPSKY
WEST COAST FLORIDA
Inline 6 so
ok guys how do you tell what gears are in your truck i just got a 2017 Big horn 6 weeks ago just love it the way it is but after reading wondering how you can tell i remember the old cars had a tag on them attached to one of the bolts head
Retiring Don
South Carolina
5.7l
What about the speedometer/odometer and cruise control? Will they require recalibration? Can it be done with an aftermarket tuner?
snoty
Orange County, California
Thanks
https://www.ramtrucks.com/webselfservice/ram/index.html
Look under "Equipment Listing" and type in your VIN to get the details.
Wm Howes
Alma Ont
What driveshaft issue? My 4x4 had an out of balanced driveshaft that FCA wouldn't acknowledge
The regular cab shortbox 4X4's don't use the same driveshaft as the "2wd" trucks do.The 8 speed regular cab shortbox 2 wheel drive trucks use an oddball driveshaft set-up that has a penchant for wanting to leave the trucks with 3.92 gears.
HDHNTER
US AIR FORCE VETERAN OEF - OIF
SC
5.7L HEMI
The driveshaft on regular cab shortbox 2 wheel drive trucks can & will fail catastrophically at higher speeds, beyond the governed 105mph limit. They lose balance & explode at the shaft coupling.
IRSmart
I drink and I know things
Westminster, MD
2018 Power Wagon
6.4L Hemi
Not that I doubt the posters in here (ok, maybe just a little), but how on earth would a truck not need to be recalibrated after a gear swap? The speed sensors aren’t after the differential (to my knowledge, anyway), so wouldn’t swapping the gears out cause a speedometer calibration issue?
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Pretty sure its on the carrier right next to the ring gear.
RLJ10X
Southern Indiana
Think about it. How does Traction Control, Stability Control, or Brake Lock Differntial work if there is not a speed sensor at each wheel?
I went from 3.55s to 4.10s. No re-cal.
IMRAM
Midwest
If you’re happy don’t check. Otherwise you’re going to be disappointed.
The only thing that'll throw a monkey wrench into your speedo calibration is if you change tire sizes.
