IAC removal
DDean
trying to remove it to clean. having issues getting the screw out help please
DDean
DDean
I just put everything back together and the check engine is on. Is that normal
BAILEY1
St Tammany Parish, LA.
2017 RAM 2500
Dat Cummins!
If you left the battery connected while you were taking things apart might have caused that. Pull the battery cables and reset the ecu. That should remove the code. Let me know if cleaning the valve fixed your idle issue.
DDean
DDean
Cleared the code. Finally got the screw out and cleaned it. Was pretty nasty. Idle appears to be normal
