Ignition switch problem
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
So, I just wrapped up putting my lower dash back together after installing two toggle switches. I put my key in to start is and the key went in just fine but was really difficult to remove my key from the ignition. So, I got it out and now, I have to push they key in with a good bit of force and removing it takes the same amount of effort. The thing that gets me is that I didn't even mess with the ignition switch at all. Has anyone else ran into this problem?? If so, anything I can do to fix it? Thanks in advance.
Adam
AustinB
Banned
San Diego, Left Coast
A lot of bad luck.
When I had a column shifter, and a standard type key... It would do that if I didn't jiggle it (shifter) in park, to make sure it's in all the way.
IMO
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
A lot of bad luck.
IMO
I might take it for a quick test drive but I did disconnect the battery to finish the electrical tie-ins I had to get done. Not sure if that affected anything. I have the key that's the ignition key and key FOB in one unit.
Adam
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
Well I think I found the problem. Rechecked all the wiring harnesses and the one under the steer column wasn't "clicked" into place... :idiot:
All works fine now...
Adam
Reactions: 9th
sbarron
Wasilla, Alaska
Any of your wires or work you did behind that panel interfere with the ignition mechanics at all. Your key is right above your switches, no?
Drummin4jc
Drummin4jc
WWG1WGA!
SW Pennsylvania
2024 Ram 2500 CC
The ignition module is actually up and to the right of the wiring I did. What happened was I unplugged a harness from the steering column that was in my way and must not have pushed it all the way to "click" and I believe that's what caused the problem. After I clicked the harness into place, all was just fine.
Adam
joshhhh
