Ghost270
- Jan 10, 2015
- 20
- 1
- 2007
- Hemi 5.7
I have a 2016 Ram 2500 Tradesman with the 6.4 Hemi.
Upon start this morning I noticed the ignition wasn't quite in its usual starting position and the key would not fully insert. Upon closer inspection I noticed the spring loaded center insert the key pushes against was fully seated and not in its relaxed OFF position. However the truck will start by just slotting the key into the ignition as far as it will let me and turning it on. The truck stayed running as normal all the way to work with the keyfob resting on my center console. When I got to work I noted the ignition would not come to rest in the OFF position, but between OFF and ACC.
I have tried starting it and cycling through P R N D back and forth to no success. Gentle pressure on the ignition would not force it into OFF, however I did not apply much force in fear of further breaking something.
Aside from just YOLOing on a new ignition switch, has anyone else seen this problem? I've searched other threads where folks keys have gotten stuck in the ignition, however for me its just the switch acting up.
I appreciate any info or help with this!
