Illuminated cup holder help
hemipwrd
Rowlett, TX
So I ordered some led cup holder inserts. They require to be connected to a switched 12v source, which is fine but I want to connect them to a source that is only on when the headlights are on. Anyone have any suggestions as to where to find a switch that I can tap into? It’s a 2012 with the floor mounted shifter. Thanks!
Dinky
Oregon
Run it over to your head light switch..
kad
Hudson Valley, NY
5.7L HEMI
If you have the factory inverter, one of the wires that runs into the dash/console plug is a feed from the parking lights circuit.
-K
TonyMM
2016 RAM 1500 CC 6"4 4X4
EDIT: deleted
TonyMM
That's on whenever the truck is on, the OP wants them on only when the external lights are on.
-K
Right! Deleted.
Quick_Shifter
IG: @ak_trucks_pa
TOTY Winner
ASTON,PA
AK Trucks Tuned 5.7
What insert kit do you get? I also have a 2012
The harness that runs up your drivers side A pillar has the wire for the ceiling console led (Factory cup holder light) that would be your best option.
hemipwrd
hemipwrd
Rowlett, TX
Thanks for all the ideas, I figured it out. Here they are with headlights off and headlights on!!!
kad
Hudson Valley, NY
5.7L HEMI
Looks good. Where did you end up tying them into?
-K
hemipwrd
hemipwrd
Rowlett, TX
-K
I tapped into the light that illuminates the gears to the left of the shifter. Turns out it’s only on when the headlights are....exactly what I wanted. Easier than I thought it’d be.
TonyMM
Thanks for your thread! I also have some cup holder lights but they are connected to a switched 12V.
Your idea to get them on only if the headlights are on is brillant! (I have a 2016 with the rotary shifter however)
hemipwrd
hemipwrd
Rowlett, TX
If you have Facebook, the guys name is mark bishop. He said he’s gonna work on getting an email setup for people who don’t have Facebook. He does them on his off time so it takes about 2-3 weeks to get depending on how busy he is. Once he gets me his email I’ll let you guys know in case there’s more interest.
shadowhawk
Southeast WI
hemi 5.7 with I2 tune
quick FB search for that name brings up a few Mark Bishops... go figure :)
hemipwrd
hemipwrd
Rowlett, TX
He lives in Colorado and works for Trinidad police Dept. Hope that narrows it down a bit....
shadowhawk
Southeast WI
how much did they run you? and I did find him with the additional info. i don't want to bother him if they are priced like unobtanium :)
RoadRamblerNJ
Mountain City, TN
392 Hemi
Glad you got them working how you wanted.
Honestly though, if you're too drunk to find the hole, probably shouldn't be driving. [emoji61]
TonyMM
The only light that I found was the tiny light in the overhead console lighting up the middle of the console and the cup holder. Is this the one that you mean?
