in need of a pro advice (2" or 4")
miraj
hello there fellow ramers,
so here am i standing between those choices . should i get a 2" or 4" lift kits ?
and which brand is better for me knowing that this is my daily use ride so i need a smooth ride on the road and of it .
my friends tell me to choose fox brand or king (which are locally available to me no hassle) , but id rather to hear from someone that owns a ram and knows what am looking for .
thanks in advance .
Revo
Canada
5.7L
What you're looking for in terms of lift amount is entirely up to you and what you're trying to go for. Are you wanting to run bigger tires? Fox and King are shock manufacturers, they may make some adjustable shocks, but not lift kits. A 2" lift is most likely going to be made to level out the truck, whereas a 4" would have either 4" all around or some more in the front, kits differ.
Lot's of guys will tell you that if you go with the 4", you'll regret not going with the 6" (which once again depends on preference). Is your truck a 4x4?
xrsman
Ontario
3.0 Ecodiesel
Yeah what Revo said. Do you want to level the truck, or lift the truck? Huge price difference as well. You're looking at $2500+ for a suspension lift and maybe $600 for a leveling kit.
My truck has a 2" level and 3" body lift. It cost me $1900 installed.
Then you need to think about tires. With a level you can use your stocks..if you lift you'll want 35's minimum. Are you trying to maintain fuel mileage, or does that matter?
For leveling I'd recommend Bilstein adjustable shocks
For a suspension lift I'd recommend Zone or BDS
Sent from my SM-G920W8 using Tapatalk
Ratket
Arizona-
^ that truck looked familiar... then I looked for the light bar.. and said maybe not.. then I looked closer and saw the brackets but no light bar... Did u tear it off??
king and fox shocks - like comparing a dart to a challenger-
xrsman
Ontario
3.0 Ecodiesel
It's an older pic of the truck when I had the light bar off lol. I wiped out in a swamp into water with my phone in my pocket and lost all my pics from the last 2 months. I have to take some new ones of the truck to replace the ones I lost lol
miraj
miraj
Thanks for your time
And yes i have 4x4 and i want this for off roading , i don't mind bigger tyres also
autokraftgt
Hemi 6.1
$600 for a leveling kit!!!!!
I paid 55 bucks for a HBS 2" level and was done in 3 hours
xrsman
Ontario
3.0 Ecodiesel
Well $200 for the bilsteins, then 3 hours labour at $85/hour. Come in around $600
ag1001
V6 3.0L EcoDiesel
I'm not a 'pro' but if your trying to get a general idea of what your ram might look like. This is mine with a 4.5" lift in the front and 1.5" rear. I personally don't want it any higher and it still rides smooth. I also use it as my daily ride and only notices my mpg went down from 22.3 to 20.5.
PCT
2019 2500 6.4
Northern California
Im going to post both, My 13 and 04.
My 13 has a 2.5 inch lift in the front nothing in the rear, im running 33s
My 04 has 3 inch in front add a leaf in the rear. I ran 35's with minimal rubbing,
My 13 Cost about 350 for lift alone but i did tires so new tires mount balance and lift came to about 1400
04 was already done when i bought it added 35's
dterrel
