Inertia 400 CI Stroker pics!
sawcut64
sawcut64
Arlington/DFW Texas
Actually this may wind up being part of his budget series of strokers? No 100% sure yet where this one will fall.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Sam I have the pics and measurements trying to load them in photobucket now.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Place I measured from on drivers side, sat ontop the valve cover on the front
On the pass side ontop of the valve cover with the CIA holding it up
14" cardboard strip
Pass side with hood closed 14"
Drivers side 14" closed
Under hood bracing and lay out
I tried 15" and they cleared, 16" folded up on the driver side and close on the pass side. I think the supports are gonna be the issue if your needed more then 15"
sawcut64
sawcut64
Arlington/DFW Texas
Well actually the way the TB sticks so far in front of the actual intake I need that clearance on the front side of the ALT/AC....
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Ok give me a few and i will try seeing if it will change it to where it wont work.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Where do you suggest I maesure it off of? It looks like the tb sticks out the front poss overtop of the belt.
sawcut64
sawcut64
Arlington/DFW Texas
The front of the TB basically sits directly over the belt. I have no doubt the TB will clear the hood it's just the added 6" I'll need for the CAI elbow. I just kind of eyeballed it from where the head meets the block and it needs 14" of height from that point. I have an extra front cover that will need to to be modified and I'll probably mock this up when I do the swap....hell man I may just finish it off and use it with all the work it takes mocking it up even though it will have a pretty substantial port mismatch.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
I got new photos give me a min I think these will be alill better for point of reference.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
These pics are off my front cover, its prob gonna be the best to show you the distance due to it sits right at the lowest part of the hood.
14" sitting right ontop of 5.7 front cover
Hood closed with 14" and small amount of clearance, poss another half inch
Thats dead center of the motor im sure you have a semi normal 5.7 truck motor sitting around to where you can tell how much diff the front cover is gonna go up then subtract my 14" cardboard from it.
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
No prob keep us posted and I can helpout with anything else.
sawcut64
sawcut64
Arlington/DFW Texas
Well I finally got my slacker ass in gear and am in the process of 5.7 removal, should have the stroker fired up tomorrow afternoon!! I took a good look at my stroker shortblock buried underneath my winter coats and decided to get my *** in gear. Also a pic of a column dual gauge pod, I'll have the trans temp on the right, wideband on the left, and the oil pressure in the SRT-10 pillar pod.
truckin151
2013 sport
I cant wait so see that thing in there and running, gonna be a beast
KGBIGCOUNTRY
MECH, VA
2004 RCSB/2005 QCSB
Bout time Sam, you still gonna run a Stu version of the Comp 273?
sawcut64
sawcut64
Arlington/DFW Texas
Yep that's whats in it now. Didn't get it done today, got a later start then what I wanted and just ran out of energy. Need to give it a bath when this is all done, pretty grungy under the hood. Running the stock heads for now until I can afford the 09' heads, but I'll be installing a ported 6.1 intake in the next couple months.
ChloeBrooks
