Inez control arms (camber adj)
ryan russell
Springdale Pa
Ok I got my truck on belltech 2/4 kit and have Inez camber adj front control arms to go on.. how do I know where to set them? I'm barely out on my camber so only a few turns each 2-3 turns maybe? Any help would be great.. thanks in advance....
hdoggie24
Huntington Beach CA
I plan to go 3" up front. I have the belltech 2/4 as well. Im hoping these would help with alignment so I'm definitely following this thread. Hopefully someone can chime in on this
ryan russell
ryan russell
Springdale Pa
But I'm going to throw my old wheels and tires on so they don't scratch up my 22s with the alignment part that go on the wheels lol
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
If you are only at a 2" drop, then I would expose about 1/4 of threads on the upper arms. That will get you very close so that the alignment shop can dial it in perfect.
ryan russell
ryan russell
Springdale Pa
Thank you very much I seen Inez said about 3/8 threads showing
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
That is how much we pull out with their 4" kit. With only 2" coils, you wont need to come out that far.
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
quarter inch is nowhere near enough so I got to take my truck home and make more turns on it to get it in alignment
How low is your truck? Most trucks do not need any adjustable arms to get it to align with only 2" coils, so you should not need more than 1/4".
ryan russell
ryan russell
Springdale Pa
It's a 2/4 kit.. I did a 1/4 inch and it's 7 degrees off still with the bottom all the way in! My truck was never wrecked either. So I'm gonna turn it out more
Hemi450hp
Moe's Performance
Conroe, TX
2014 Ram 1500
That just doesnt make sense as its very rare that anyone has to run the adjustable arms with only a 2" front drop. Was it out of alignment prior to installing the arms, or did you install the arms from the start with the lowering kit?
ryan russell
ryan russell
Springdale Pa
I installed the lowering kit had it adjusted or aligned as you say it was very close but the camber was still out a degree or two I probably should have left it but I'm very **** so I bought the arms off of a member on here they were never used just put them on yesterday.
Jimmyzrx
Joplin Missouri
I have a 2014 ram 4x4 with belltech 2/4
I just had a alignment today.
They said I need adjustable a arms.
Jimmyzrx
Joplin Missouri
Yes it seems to ride good
A little former but nothing like my 88 s15 back in the day lol.
I’m running 305/40/22 and all fits well together
Reticle918
