Inez cut kit or NON cut kit. 2/4 drop
Josh22855
Inez Hotrods 09-18 Ram 1500 Rear Control Arm Brackets (CUT-KIT)
Truck has a 2/4 lowering kit, control arms sit at a horrible angle, I know if I do not address this my track day will be bad, lol. My question is does the cut kit make the control arm sit closer to the ground (giving it a better angle) compared to the non cut kit?
Or is the cut kit just to free up clearance between the truck and axle? Any and all help is appreciated....also is there any other brand out there other than Inez I can use?
2016 ram 1500 regular cab.
I think it also moves the upper arm down,but don't quote me on that,lol. My Illicit brackets move both arms down. Jason Duria was mumbling about somebody building another option besides Inez for brackets,but that was probably 6 months ago now,and i haven't heard any updates since then. As far as i know at this moment in time,there's only the Inez versions.You can track Jason down on Tuned Rams on facebook and check with him though.I know Kyle Tingle told me awhile ago he was going to be testing out a couple versions of brackets,and i'd hazard a guess one of those sets will be the ones Jason was talking about
Josh22855
Josh22855
They look good Josh.Do you have access to a small mig welder,if you do,it doesn't hurt to put a couple tack welds on them to keep them from moving around on the bolts,it'll also cut down on your bolt maintence
Very good idea, yeah I have a buddy with a mig welder. I did trans fluid and filter replacement today(amsoil), that would have been a perfect time to have tacked them brackets also....
Bluestarrider
North Carolina
I used the Inez no cut brackets on my 2016 for the sake that it would allow the truck to be returned to stock in the future if desired. The brackets do relocate both arms. These brackets in conjunction with sphon adjustable track bar and track bar relocation brackets makes rear geometry almost perfect and ride quality very nice. If you use the Inez brackets, removal of the rear bump stops as they instruct is a must, the complete bump stop not just the rubber portion.
6speed4.7
Winnipeg
After you removing the metal cups, did you install shorter ones?
1SloRam
Ms
I left my bumpstops , no issues here. Only bottomed once. I know if you’re going 6” or lower you need to cut them off, but 4” drop doesn’t require to cut them. At least not with Belltech.
6speed4.7
Winnipeg
I wish I could say the same
With nothing in the box- Belltech 2/4 drop and Illicit no-cut brackets- I’m a little less than a 4” drop and am resting on the bump stops
Previous lowered trucks I’ve had seemed to ride a bit better with my tools in the back, maybe compressed the bump stops a bit more than just bouncing on them
When the weather changes and before I go back to work I may just remove them, not cutting anything out, and see how it rides
I got a few replacements to try if it rides better with them removed
Bluestarrider
North Carolina
I not only removed the rubber, but also removed the pockets from the frame. My truck bottomed out everyday on the road i live on before bump stop removal. No issues since.
6speed4.7
Winnipeg
Thanks, that’s good to know
Do haul much stuff around in the box?
1SloRam
Ms
Maybe because I’m a single cab I don’t have those issues. I don’t haul much or often at all, could also be why.
Steve Holtz
