Infinity system ... you dont have to replace
ramhunter9
P-Star Jeep Wrangler
I have the infinity sound system in my truck .
Each speaker has its own amp hooked right on it .
Most people cut and add new wire .... well I did some experimenting and came up with a good way to replace the speakers with aftermarket and still get use out of the amp .
First take your panels off .. unscrew the speaker and you will see a front door 6x9 wrapped in a hard shell ... this is the amp .
Take a tiny screw driver and pop the shroud off . Under this is the infinity amp .
Next take the 2 bolts that hold amp on to the speaker off .
Unplug the red + and black -
Next as you can see from the pics you will have the amp .. I mounted it out of the way so the window would not hit it . Drill 2 holes and attach on the inside of the door .
So now you only need to plug in the red and black to the new aftermarket speaker and still maintain the infinity amp on them .
The oem speaker with the shroud on it ... under it is the amp and all the wires are already attached
With the cover off ... trash that wont need
Amp mounted in the door and all that is left is 2 wires pos and neg .. hook to new speaker
The beauty of this is no more cutting or wire running .. or just plain ol getting rid of the amp ... the more power the better
Oh .. and have 26 of these before you start .. dam door tabs
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Very nice install Dave.
ramhunter9
ramhunter9
Tomorrow ... new Clarion head unit and Rockford door speakers
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Wahoo! What model Clarion did you go with?
ramhunter9
ramhunter9
Also ...
If your vehicle has the Infinity system, you'll connect the blue wire from the new wire harness to the amp remote wire from the new receiver. There also may be a second wire, usually green/black, attached to the factory radio chassis with the braided strap. If so, this is the ground for the Infinity amplifiers , and it must be attached to the braided strap and the replacement receiver's ground wire.
Luke I went with the Clarion CZ101 .. nothing fancy
ramhunter9
ramhunter9
Does anyone know what the infinity amp rating is ? Just curious
ramhunter9
ramhunter9
EDIT.. found it infinity amp is 12w RMS and 160w Peak ..
The head unit is 18w RMS , so ya I will be happy
HemiBabe
DFW
I tried a search and found 160 watts, no clue if thats right or not.... maybe it says in the manual?
EDIT: nevermind haha
ramhunter9
ramhunter9
^^^^ :crazy:
quietpeen
2021 TRX
Hellcat
sweet write up. Cool deal on the clarion coming next
ramhunter9
ramhunter9
I wonder if this would work for the other gens also ?
RubberFrog
Third gen has a single amp behind the glove box.
quietpeen
2021 TRX
Hellcat
yea on the 3rd gen there is one amp and i believe if you want to keep using the amp but replace the speakers you want to get 2 ohm speakers.
ramhunter9
ramhunter9
ahh .. well than this is 2nd gen only I think . As they have amps on each speaker
LB3711
Trumbull, CT
3.6L V6
4th gens have a single amp under the dash on the drivers side
wermbang
Iowa
2001 Off Road
5.9L V8 Sport
Yeah this is 2nd gens only
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Yup us outcast 2nd gens have all the multiple parts. lol I did this mod and it works out really well!! Truck sounds great!!! And didn't have to spend a ton!
ramhunter9
ramhunter9
I have heard your system in person ... it does sound good
Bigtman07
Registered User
Piqua, Ohio
Cummins 5.9
Well thank ya sir! We are gonna have to do it again sometime.
ramhunter9
ramhunter9
Fo , sho
