Injector tic/noise ?? Anyone else have similar noise ?
BEAST19
Anyone experience this?? I have a vararam intake , so my engine cover is off . Possibly making this noise more noticeable . Echoing in the engine bay .... I brought to my mechanic who installed my headers ... he took a stethoscope to the engine and we both listened and determined the noise is coming from the injectors equally and not the lifters (ruling out the infamous lifter tic) ... should I be concerned with the injector noise? Or is that normal and I’m being hyper sensitive to the issue? I’m thinking maybe the winter gas is playing a role? I still run 93 octane but maybe the increase in ethanol?
Attached is a video of what it sounds like ....
https://youtu.be/urHdGhd9v5s
BEAST19
'15 Ram 1500 5.7L
Blacked out brilliant black bighorn
Fully functional hood
Custom quad switchback halo
Fuel vapors wrapped in 33"x12.5nittos
MBPR Exhaust
ARH Longtube headers
Pedal Commander
Vararam intake
Diablo i2
Painted bushwhacker flares
Color matched cab spoiler
87mm TB
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Yours is louder than mine but you can hear my injectors fireing off.
probably with your cover off and the headers are making it louder.
BEAST19
BEAST19
Good to know that others can hear it too. I’m gonna put the engine cover on tomorrow and see if it quiets down. Normal noise tho in your opinion?
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
69GWC
Power Wagon
Spring hill, Kansas
2022 Power Wagon
6.4 Hemi, 8sp
Well normal as mine does it as well.. lol yours is just louder than mine but mine has always made that noise since the first time I fired it up.
Ramnewbie
My injectors are quieter whenever I give it a shot of Lucas Fuel Treatment. I don't run this all the time, probably every 5th or 6th tank or so, ok, actually whenever I remember it's been a while. I know some have reported that they run some sort of upper cylinder lube all the time.
BEAST19
BEAST19
Anyone think maybe the pedal commander I have installed is contributing to this????
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
I run my 14 with the cover off,and my injectors sound pretty close to yours:favorites13:
BEAST19
BEAST19
Update: took truck to dealer to have a tech listen and he stated it's nothing he'd be cincerened with ... light ticking of the injectors is normal. And could be amplified throughout the engine compartment with the LT headers and vararam mod .... Eased my mind a bit. Of course he said if it is something wrong it'll get worse and louder and nothing I have mod wise should be to blame for it .
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
Nutshell
Some guys run TWC3 in every tank and swear it quiets down injectors
^^ yeah try and upper cylinder lube of some sort, but I'm not 100% it is injectors. What oil are you running? Has the noise ever changed cadence at all with an oil change? I don't think pedal c has anything to do with it and it borders on normal. I'm not sold that it is injector noise, it isn't standard hemi tick for sure, but maybe it is just a little raspy in the lifters. I'm not saying that is what it is, just a possibility. First try an upper cylinder lube or two, Redline s1, Lucas, TWC3, I don't think it would matter which one of these because you are just looking for the oil in the formula, not the cleaner. I'd probably just get lucas first, easy to find and cheap. If after a couple bouts with upper lube not working- if that becomes the case, then I would consider oil and filter combo's.
BEAST19
BEAST19
Thanks for the info.... I'm %100 it's the injectors ... I personally listened to each one with a stethoscope and then listened to the lifters completely different sound and the sound I hear is exactly what I hear with stethoscope except obviously amplified . But I am running my tank for the first time with Lucas upper cylinder lube . No chang so far .... I also think its more noticeable with trucks that have longtubes for some reason .
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
BEAST19
BEAST19
Btw I'm running amsoil 4qt 5w20 with 3qt redline 5w30 with rp filter
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
Nutshell
I have noticed trucks with headers do tend to sound a little ticky. You remove those thick cast iron logs and replace them with thin wall stainless, valve train noise is bound to be amplified.
The big question on injectors, does any vendor make an aftermarket upgrade in stock PSI?
I owned an 88 Vette that the injectors ticked horribly, I replaced the stock injector with rotary disc style and it was quite as a mouse...nice performance gain too.
BEAST19
BEAST19
Ah good point . I’m not a mechanic by any means but that makes sense to me . I think a lot of people mistake injector noise for a lifter tic./ hemi tic . But Yes I’d be interested on upgrading the injectors if that were an option. I’ll have to do some research . I wish there were a performance shop near me that dealt with Rams specifically.
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
Nutshell
BEAST19
'15 Ram 1500 5.7L
MBPR Exhaust
Pedal Commander
Vararam intake
Diablo i2
87mm TB
Guys that specialize in these trucks are hard to find...good ones anyway
forgottengem
tennessee
i just replaced cam with an FRP hellfire 2.0, hellcat lifters, high volume oil pump, mds delete, high flow water pumps and im still ticking... went over it with a mechanics stethoscope... the entire injector rail amplifies the tick... thats where its coming from and every single one of them sounds the came!! (vararam as well)
ChloeBrooks
