Silverfish
I am about to install the Kicker Key180.4 amp and I'm a little confused as to how to wire the speakers into it. I'm assuming the best method is the tie into the factory speaker wires behind the head unit? And if so do I cut the wires coming out of the head unit and just wire them to the input wires of the Key amp or do I tap into them so that they are still hooked to the factory head unit and to the Key amp at the same time?
For reference I've already changed out the factory door speakers to aftermarket speakers. And I have the 8.4 factory head unit with base audio. I do not have the factory Alpine system. 2016 Ram 1500 crew cab
Thanks in advance for any help you can give on this!
