Installation troubles
Mudder
Arkansas
So I got around to installing my Pioneer AVH-2300NEX today. I was upgrading from a 5.0. I used the idatalink maestro RR and CH3 wiring harness. Got it all wired up according to the directions. It all seems to be working fine (aside from my breaking the uRam in the center console). However, now I’ve got a check engine light on all the sudden? Any ideas on what I could’ve done wrong to cause this?
yillbs
Likely nothing, or a faulty ground. Get the code ran and figure out what the error is.
barbosa
Same thing happened to me when installing the exact setup. It will clear itself after a few key cycles.
Did you start the truck at any point before reconnecting all of the harnesses in the dash?
adurm
FL
2015 RCSB
What barbosa said. I didn't have my tranny switch plugged in before i turned the key on. I got a check engine light that went away after a few cycles.
Mudder
Mudder
Arkansas
You guys are 100% correct. I did switch the key on before reassembling. Light went away in the Petco parking lot yesterday. All seems to be good. Loving the new radio and cuz I’m old school, the CD player.
