Installed a Sony XAV-AX100 in my truck
blackbetty14
CT
Hemi 5.7 VVT/Etorque
I may just get a new phone. Apple is offering $300 off if you trade in an iPhone 8, and I know I wouldn’t get that much for it a year from now. If I were happy with it I’d keep it but the constant lagging and hanging when I’m trying to type is really annoying me.
Anyhow, I’ve just been trying to open XM from the CarPlay interface. I listen to the same 3-4 channels so when it does work it’s actually not bad as the app opens on the “Recents” tab.
Yea that’s what I do as well. The recent tabs covers 3 or so apps so my maps, XL and phone are prob always there.
I actually just got th new iPhone XS max tonight and it’s a huge jump over the 6s.
B
Cummins 6.7L
Does your back up camera work with it?
Factory guidelines that turn with the steering wheel are still there. The image quality is great.
Hookie
Eastern Ky
That sounds like just what i'm looking for, only I'd have to pay someone to install it for me. We don't have any reputable shops around here.
B
Cummins 6.7L
Here’s the reverse cam ...
Craigger
Norfolk VA
5.7L V8
Can you send the link of where you got this or give a little direction on where you bought this from please? Really like it and want to emulate it with my Ram. Thanks for sharing
Craigger
Norfolk VA
5.7L V8
Ok sorry i found it. Can you post a picture of how you mounted the USB bracket? And it says you lost the AUX input connection. Did you modify anything to keep that functuonality or is it unneccessary due to bluetooth?
B
Cummins 6.7L
B
Cummins 6.7L
I’ll get a pic tomorrow .... this radio has no aux input so there’s no way to keep that function.
You can use Bluetooth audio, or you can just use CarPlay to play whatever audio is coming from your phone.
B
Cummins 6.7L
Pic below..... as you can see, it doesn’t quite lock itself in just right. I could easily tack it down with a little glue, but I purposely haven’t done so yet because I’m pretty sure as of right now I’m going to try and move this to the center console.
I’d like to try and modify one of the OEM usb charge ports to use a USB extension cable and replace the 12v outlet in the console.
It’ll be another couple of weeks before I have time to try it, but I’m going to open the dash up this weekend and look at the USB charge port I have now to see if it’s even possible.
Craigger
Norfolk VA
5.7L V8
I have the center console USB jack in my 14 Ram 1500. Do you know if with the harness already built in the Sony, i would be able to continue using the factory jack
B
Cummins 6.7L
Any plans to replace your speakers?
I’m currently rethinking my original statement to not replace the speakers.
This truck was back in the shop this week, so I drove the Laramie we have with the alpine system for a couple days and forgot how much better that sounds.
I may go ahead and order dash & front door speakers to see if I can get any improvement. I just don’t want to get too far down the rabbit hole and end up spending a bunch of money on this. I can live with how it sounds but if I can get some improvement for a couple hundred bucks I’d be willing to try it.
Craigger
Norfolk VA
5.7L V8
Are we talking just replacing the front dash and door speakers to Alpine?
B
Cummins 6.7L
Not specifically alpine, just a better quality aftermarket speaker.
Craigger
Norfolk VA
5.7L V8
There has to be something better than stock without paying the "Alpine" price. Id search at best buy, maybe even HHGregg
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
Do you lose being able to adjust settings available in the factory head unit?
B
Cummins 6.7L
Yes, which I was slightly worried about. The XAV-AX210 is compatible with the Maestro unit but is $200 more, plus the maestro.
My settings have only been reverted twice by the dealer when in for service that I can remember.
But if it happens again, it would take me about 20 minutes to pull this radio, connect the factory head unit and reset them.
The way I have this radio installed I wouldn’t have to remove it to get to the factory harness. I should be able to pull it out enough to connect the factory head unit without removing the Sony. But even if I do have to remove it, that’s a 5 minute job to pull out and out back.
My trailer brake gain settings are adjustable through the factory brake controller in the dash, so the only settings I would need to adjust with the factory unit are the headlight delay and door locks. Nothing I’m too particularly concerned with right now.
B
Cummins 6.7L
Looking on Crutchfield, and searching by power ratings of this radio, it looks like I can replace them for less than $200 with what should be decent speakers.
Michael
In an undisclosed bunker
I spent about $250 on dash speakers and speakers for all four doors. I used JBL Club series 3.5” for the dash speakers and JBL Club series 6x9’s in all four doors. The sound was a major improvement over the stock units while still using the stock head unit. I highly recommend them. If you buy them from crutchfields, like I did, they include the harness adapters so it makes it an easy plug and play installation.
SixFOURhemiHD
Ghost Rider
Alabama
6.4L 392 Hemi
What does the maestro unit do?
Goodie1990
