JayTee82
Yup, thats it. it'll be a orange with a purple strip wire.And pin position 2 is the lin bus? For the Homelink at the green connector?
If so, I’ve been looking for this for three years....
Any chance you can find the pin out for that connector. Im gonna need to make a extended harness to reach down there at some point when i upgrade my back window too. I think i might just cut my connector in the truck since its only one wire in it. Extend that wire and then add the pins and wires i need for the slider motor.
Male pins, body side-Any chance you can find the pin out for that connector. Im gonna need to make a extended harness to reach down there at some point when i upgrade my back window too. I think i might just cut my connector in the truck since its only one wire in it. Extend that wire and then add the pins and wires i need for the slider motor.
Is power backlite the rear window? I think so, It shows - and + like it reverses polarity for a window motor. Probably need that "Fused B+" too for the window. I hate to keep bothing you. Can you find schematics too rear slider window?
Cool! So looks like i just need to run wiring for 1,8 and 7. My ground and fused ignition are on the left side connector. Any idea where i might be able to purchase terminals? I assume you work for Ram since you have all these schematics.
Actually i just looked, i don't have the fuse ignition wire in the cavity on the body side. Gotta find a ignition source for that too.
No, don’t work for ram. I have a subscription to the service manual.Cool! So looks like i just need to run wiring for 1,8 and 7. My ground and fused ignition are on the left side connector. Any idea where i might be able to purchase terminals? I assume you work for Ram since you have all these schematics.
These terminals are specifically for the 14 pin connector I have pictured above, and it’s mating connector. All the connectors throughout the truck are made by various manufacturers with different terminal sizes, so it’s important to be specific which connectors you’re referring to. Yazaki 7114-4101-02 are the small male terminals for the body side connector. 7114-4111-02 are the large male terminals for the body side connector.
Yazaki 7116-4101-02 are the small female terminals for the headliner side connector. 7116-4111-02 are the large female terminals for the headliner side connector. You can buy them here- https://www.kaodtech.com/connectors-and-terminals These are sold by our member DeereGuy, who also builds harnesses for factory mods like what you’re doing.
