Installed LED reverse and cargo bulbs now RR signal isn't working plus bulb out message
Kelownapaul
Kelowna
6.7 TD
I don't understand what reverse lights and cargo lights have to do with my turn signal. Anyone have any suggestions? 2011 ram 3500 6.7. Thanks
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
I installed LED reverse and third brake light with no issue at all. I would start with checking the RR connection. You may have loosen it when you changed the reverse bulb, if still not working change the RR bulb, a cheap test ,
K
Kelownapaul
Kelowna
6.7 TD
Thanks for the reply, this was my first foray into the led world. It was indeed a bad bulb, the filament was broken from probably getting flipped upside down while doing the reverse lights. All is good now
SitKneelBend
Moderator
Member Relations Specialist
St. Louis
3.6 Pentastar
This may sound silly or not work in reverse but try switching the new LED bulbs around 180 degrees in there sockets. If they still light this way go through them one by one and see if the message disappears.
Rado
US NAVY VETERAN
Navy Badge
Maine
Pentastar 3.6 V6
Thanks for your update, As the saying goes crap happens lol Glad it was a easy fix
