Installed my panhard bar and my nitto's
blackout11
alpharetts GA
2011 R/T
Then me and my bud went for a ride and guess what no more rear end shake
Big Boi
S. Fla
What made it shake in the first place? How much?
blackout11
blackout11
alpharetts GA
2011 R/T
Well im going to have to say the stock panhard bar i could not go over 70 without the ass end wagging like a dogs tail i got the tires installed and then i put on bar adjusted it and BOOM hit 100 4 times and perfect.
Was 150 i was going to remove the beltech bracket first but it works fine now so im not touching it
Hell might have even been my old tires lol who knows
These tires are great i hit a corner at 60 and it hugged it like me hugging jennifer love hewit
SILVER_BULLET
Nice I need to order mine also and the control arms to really center everything
fdnj48
Central NJ
Nice! Looks good!!
Sent from my SCH-I535 using Tapatalk 2
Speedy McD
2016 Express Single Cab 2x4
Pentastar V6, 8 Speed
Part number for the Panhard??? Where did you get it?
BlkRamRt
SoCal
HEMI 5.7
when you installed it do you have to lift the truck up or did you do it while it was on the ground?
WhiteExpress
Midland, TX
I'm thinking I might should upgrade my Panard too, even at stock height I think the rear suspension is sloppy!
blackout11
blackout11
alpharetts GA
2011 R/T
They tell you to lift it support frame lower rear remove old one install new one only semi tighten the nuts then lower the whole truck back on ground. Shake the truck aks jump on bumper lol roll truck back and forth then adjust the bar then tighten the bolts. Also use lock tight after you adjust it
BlkRamRt
SoCal
HEMI 5.7
hahaha sounds easy now I need to go ahead and order mine.
SILVER_BULLET
so you adjust it while its on the truck and already lowered the truck back to the floor right
